Completely drain hydraulics?
Posted by Sam Comstock on October 16, 2000 at 13:44:08 from (129.82.219.1):
I'm replacing the hydraulic/transmission fluid on a 560 that sat idle for 11 years. I have drained in 3 places (rear, mid, and pto ta compartments) and have removed the filter. I got a 2-3 cups of water from each compartment, and some transmission stop-leak had been added before I got "control".
The steering is drained due to a rebuild, but should I drain the control valves and lines to the 3pt and auxilliary cylinder? The Operator's manual refers me to a Preventitive Maintenance Manual for tractors with hydraulics for the proper draining proceedure, but I don't have that manual.
As a side note, this is a Farmall, but the rear drain matched the picture in the Operator's manual for an International. Any ideas what is up with that?
Thanks in advance - Sam.
Post A Followup
: Re: Completely drain hydraulics?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
