Re: Hey Janicholson, First start and break in question
Posted by Janicholson on October 01, 2012 at 14:50:11 from (199.17.6.20):
In Reply to: Hey Janicholson, First start and break in question posted by BigTone on October 01, 2012 at 12:33:10:
Filling the system with oil can be done easily with a pump oil can. Use a bit of vinyl hose, or rubber to make a connection from the spout to the oil pressure sending threads in the block. Put engine oil in the can, and pump till it feels like you have more difficulty pumping. (it might take 3 cans of oil or many more if the filter is not full). A small cheap pressure spray tank (like for spraying plants) can also be used with success or a bleeded pressure tank. A small gear pump with the intake in a gallon of engine oil is also a possible short cut. This primes the system and assures at least a high probability of pressure. Jim
