Re: Charlynn pto hydraulic pump mount
Posted by gene bender on October 01, 2012 at 16:49:41 from (67.55.227.68):
In Reply to: Charlynn pto hydraulic pump mount posted by mkirsch on October 01, 2012 at 07:58:41:
If you are going to run it on the pto you will need a Lovejoy coupling or one similar. You are also going to need a bracket mounting the pump to the PTO assy. Or you can move the pump sideways and run it with a roller chein either way you will need to make the brackets to mount it some do run them off the belt pulley but you will need to fix it so the pump doesent turn over 750 RPMs I use two of them both on Bs. I did make a mount to run on on an A customer wanted it that way. Those are great units 10 gal per minute @1000 psi. You can still get parts for them.
