Posted by teddy52food on October 01, 2012 at 17:50:54 from (184.94.175.179):
In Reply to: leaky float posted by charlie M on October 01, 2012 at 16:48:23:
Look for a small spec of solder away from the seam. Heat it with a soldering iron & open the hole with a pointed toothpick. Drain the gas out & resolder. Then put it in boiling hot water to find the leak. Solder the leak after opening the vent. After it is cool, close the vent & test again. Try not to add too much solder or it may get heavy.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
