Re: Farmall M clutch pedal adjustment
Posted by rhtx55 on October 01, 2012 at 17:54:43 from (207.119.53.190):
In Reply to: Farmall M clutch pedal adjustment posted by BigTone on October 01, 2012 at 12:21:01:
There should be a square headed adjustment bolt on the bottom of the pedal, it has a larger lock nut on it. See if it may be screwed in too far limiting the pedal travel.
The owner's manual has the adjusting procedure and sequence to get the adjustments of both free play & travel.
Do you have an owner's manual?
