Re: leaky float
Posted by rusty wheel on October 01, 2012 at 18:29:44 from (75.180.23.218):
In Reply to: leaky float posted by charlie M on October 01, 2012 at 16:48:23:
I have used s magnifying glass to find the leak. Then open it up just enough to let the fuel leak out. When it's dry clean the spot with steel woool and solder it closed. Remove any excess solder with a small file. Then submerse it in a can of fuel and hold it down with a weight overnight. Check it the next day to see if it has fluid in it. If it doesn't,you're good to go. I have done this several times with great success. RR
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
