Re: leaky float
Posted by Heat Houser on October 01, 2012 at 19:03:49 from (69.66.35.73):
In Reply to: leaky float posted by charlie M on October 01, 2012 at 16:48:23:
Repaired the float on my 560 Farmall. There is a small vent hole as noted below. I used a hair dryer to warm up the float, rolled it around to see where the "wet" spot was. Marked it, opened the vent hole, finished draining the gas, used a heat gun to "preheat" the float, and soldered the area of the leak. Maintained the "preheat" so I could solder the vent hole shut so expanding air wouldn't blow out the solder.
Clean and shiney brass is good...LOL
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
