Re: Little Genius tail wheel ?'s with pics
Posted by mkirsch on October 02, 2012 at 04:58:06 from (64.80.110.74):
In Reply to: Little Genius tail wheel ?'s with pics posted by Dean Olson on October 01, 2012 at 19:23:17:
The "correct" tail wheel tire is a 3.50-12, smooth tread, beveled. Just like in the picture above.
Miller tire sells them, to the tune of $105. http://www.millertire.com/products/implement-tires/rib-implement-tires/3-50-12/3-50-12-firestone-plow-tire/
Most of these plows aren't worth $105.
A trailer tire works just as well. I got one at Harbor Freight It may not last as long, but you're also not plowing 50 acres every spring either. Just a few rounds to make a garden, or a few times up and back at a plow day.
