Re: 450 single spline/DUAL spline axles?? ARE THERE 2 KIN...
Posted by D Slater on October 02, 2012 at 08:06:53 from (184.15.50.155):
In Reply to: 450 single spline/DUAL spline axles?? ARE THERE 2 KINDS??? posted by mike1972chev on October 02, 2012 at 04:29:25:
Later 450 tractors started showing up with one keyway axles. Wheels used on the tractors only used one keyway even if they came with a 2 keyway axle. SM type wheels and clamps needed a 2 keyway axle. Although some replacement wheels for M through early 400 used a one keyway wheel and 2 axle clamps per wheel with 7/8 inch diameter bolts like the 450 clamps.
Saw enough 450 tractors with a 2 keyway axle on one side and a one key on the other to think maybe some left the factory like that. Or else a lot broke the axles and were replaced.
