Re: Radiator Overflow
Posted by D Slater on October 02, 2012 at 13:21:06 from (184.15.50.155):
In Reply to: Radiator Overflow posted by Tedd on October 02, 2012 at 12:01:49:
Also if not overfull or overheating that can happen when compression pressure is making it into the cooling system. Crack or gasket failure.
