Re: lead in gas
Posted by Lmack on October 02, 2012 at 14:57:42 from (24.131.58.167):
In Reply to: lead in gas posted by Ellis Kinney on October 01, 2012 at 14:46:40:
If I remember history correctly Tetra-Methyl-Lead was developed prior to WWII for aircraft fuel by the U.S. The desire was to produce higher compression aircraft engines for higher performance. The Germans in fact worried that the Allies had gasoline with lead antiknock compounds and they (the Germans) did not. Given that the Germans did not have leaded gasoline it must not have been widely available prior to the war. Antiknock compounds were not required as long as the compression ratio was held low enough. It was the mid 1950's before compression ratios in autos begin to rise to the level needing leaded gasoline.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
