1st rotate the engine until the points are open. Check and see if you have power to one side of the points. If no then the problem is between the points and the coil. Next check to see if you have power to the distributer side of the coil by disconnecting the wire and testing at the pole. If you have power throught the coil then the wire or insulator is bad. If you have power to the points close the points and slide a clean piece of paper between the points. Often oil or dirt is on them from the manufacturing process and all they need is cleaned.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
