Re: Farmall 560 no spark, replace coil, resistor
Posted by LaDuke Farmall on October 02, 2012 at 20:12:21 from (67.142.181.21):
In Reply to: Re: Farmall 560 no spark, replace coil, resistor posted by joja on October 02, 2012 at 19:42:16:
I just had the same problem with my 560. I put a coil, resistor, battery, the works. I bet you got the same problem, you points are worn or are not set right. gap them to .023 then with the cap off turn it over and check for fire. I bet its off
