Is this the solenboid with two posts one to activate the starter and one to bypass the resistor to the coil? As it is drawn...
1. Your starter runs whenever your switch is on. 2. You may not have fire because you are energizing the negative side of your coil.
Move the green wire to the other side of the pushbutton and try that. If the light blue and dark blue wires are on the same terminal it will run the starter all the time.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
