Re: Farmall 560 no spark, replace coil, resistor
Posted by charlie M on October 03, 2012 at 05:57:38 from (74.41.94.226):
In Reply to: Farmall 560 no spark, replace coil, resistor posted by joja on October 02, 2012 at 19:24:55:
Make sure the rotor is turning - I think there is a pin that drives it inside that can break off. I know there is on an H distributor.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
