Re: Please help......Working on a 240 utility and need fixed
Posted by Jim Becker on October 03, 2012 at 08:12:23 from (173.74.120.222):
In Reply to: Please help......Working on a 240 utility and need fixed ASA posted by Brad in WI on October 02, 2012 at 17:07:14:
As I recall, there should be a big internal snap ring in the hub, near the outer end. The 2 parts should press together with some very high force and stop when the snap ring contacts the axle. The flat washer and bolt should not have a lot to do to hold it together.
Sometimes the hub/axle joint loosens up. You usually find wear on both parts and it can't be fixed without changing out both parts. Sometimes you can remove the snap ring from the hub and push the hub in farther to tighten it up. You then need a sleeve over the axle for the washer to push against. This is usually a temporary "fix".
