Re: Farmall C compression
Posted by gene bender on October 03, 2012 at 17:34:53 from (67.55.227.68):
In Reply to: Farmall C compression posted by MarkinMo2 on October 03, 2012 at 17:23:24:
The one cycl being low shows some problem but it should start good does it have a mag or a dist as thats probably the problem if the idle circut in the carb is clean that circut can be hard to clean and sometimes you need a small drill to get the bottom of that passage real clean.
