Re: Jacking up tires
Posted by BigTOne on October 04, 2012 at 07:04:15 from (24.97.34.195):
In Reply to: Re: Jacking up tires posted by mike1972chev on October 04, 2012 at 04:01:52:
Mike, when I first got the tractor I had no tires/rims on it and it had fallen off the blocks that were under it so the only way to jack the tractor up was to put the jack under the u bar corner and it bent it a little. I now have tires/rims on it and can get the jack under where you said but it just doesnt seem to be safe enough, i like the blocking/bottle jack idea more. thanks for the help
