Re: IH/Farmall 140 Production Changes, Need some help Ide...
Posted by Erik Dekeyser on October 04, 2012 at 14:21:17 from (184.151.61.3):
In Reply to: Re: IH/Farmall 140 Production Changes, Need some help Ide... posted by RTR on October 04, 2012 at 09:06:27:
Ok the later ones have a larger serial number.Mine is a 1979 serial number 65647. The last 3 years are all in the 60000s numbers. They are all just key starts and no push buttons. They have 2 flashers and the shrowed around the fan is bigger than the early models. They also have a spin on oil filter and an altenator instead of a generator. Hope that helps Erik..
