If i were you i would quit looking at the steering wheel centers they are real easy to change. Look at the steering, is it tight? check the right brake pedal if its real sloppy the tractor might have a lot of hours on it. Check the draw bar hole is it egg shaped? Check for a noisy transmission or hydrolics and check the oil presure.Does the engine smoke? Make sure it has good tires they are not cheap to replace. Thats what i look for when i look at a 140.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
