Re: Generator on an A question
Posted by 440roadrunner on October 04, 2012 at 19:46:30 from (76.178.190.178):
In Reply to: Generator on an A question posted by teddy52food on October 04, 2012 at 17:44:04:
If you don't care about originality, ANY cutout of the proper voltage will work
You can make one out of a great big diode. Just put it in series with the armature to battery mounted on a heat sink. You will have to use the insulation washer kit with the diode, and thermal grease, or insulate the heat sink.
I know the purists will hate it.
