Keep in mind a turbocharged gas engine sucking through a carb does not function like a diesel. When engine is under a light to medium load like running up and down the road like the op said, there is no boost because the butterfly in the carb is staying near closed to keep rpm's steady. A diesel controls rpms by restricting fuel when a gas like this is restricting air and gas mixture, hence, no boost until the govenor opens the carb under a heavy load. your problems are not boost related if you are only running on the road. I need to know what type of engine failures you had before to diagnose. As of now it sounds like you are getting coolant into cylinders.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
