Re: Seal for Cub PTO angle shaft.
Posted by Haas on October 05, 2012 at 07:12:05 from (75.200.187.78):
In Reply to: Seal for Cub PTO angle shaft. posted by Farmallb on October 04, 2012 at 12:08:09:
The bushing goes over the splined shaft and bears against the bearing inner race and acts as a bearing retainer. The bushing is held in place when you install the belt pulley which is held by the bolt in the end of the shaft. If the pulley is not on there, then there is a sleeve that goes over the shaft and held in place with the same bolt that holds the pulley in place. Go to CNGCO.com or call them up and they should be able to get all the parts you need.
