Re: Free Play?
Posted by pete 23 on October 05, 2012 at 10:45:25 from (74.32.238.2):
In Reply to: Free Play? posted by BigTone on October 05, 2012 at 10:16:07:
It is the 7/8th from pedal to platform. Just realize the actual measurement is not all that critical. What you are after is movement of the throwout bearing. It has to be clear of the clutch fingers when pedal is back against platform. Sometimes, linkages are worn and one has to compensate here and there . You want bearing to be away from fingers about 1/16th to 1/8th inch and still get full clutch release when you push pedal all the way to the stop. As the clutch linings wear that clearance decreases so you keep an eye one it as you are using it to make sure you always have some free travel.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
