Re: 450 clutch
Posted by earl in pa on October 05, 2012 at 14:56:22 from (96.247.177.180):
In Reply to: 450 clutch posted by earl in pa on October 05, 2012 at 12:12:15:
I may not have made my problem clear. It only fells like the brakes are dragging when it is gear. But if I pull the torque back it seams to release and will move like normal.
