Re: Late Model Farmall M w/ Disk Brakes??
Posted by Haas on October 06, 2012 at 07:14:33 from (75.246.135.194):
In Reply to: Late Model Farmall M w/ Disk Brakes?? posted by claytonmcnamara on October 05, 2012 at 17:15:59:
I have an MD with the after market Lambert brakes. When I rebuilt them, around 10 years ago, you could get parts from IH. Probably no more. And 10 years ago the part were costly. I took my disks to the local clutch brake rebuild shop and they relined the disks for me at about 1/4 the cost of new disks from IH. If you want to keep these brakes on your tractor(they are a bit unusual), I think you could have a machine shop resurface the actuator parts that contact the disks if that is needed. I just sanded mine off. The only other parts likely to be of consequence are the balls and springs and you can likely find replacements for those that will work. If the grooves the balls run in are rough or corroded, that could be a problem. After I put the relined disks in mine and cleaned everything up, they are still working fine 10 years later.
