Re: carburetor trouble?
Posted by Bob M on October 06, 2012 at 10:50:56 from (74.67.191.50):
In Reply to: carburetor trouble? posted by TTks54 on October 06, 2012 at 10:27:21:
Sounds like the carb float is not regulating the fuel level in the bowl. Possibilities include an improperly adjusted float level, failing (leaking or binding) float, a worn out float valve, a bit of trash caught in the float valve, etc.
Unfortunately you'll need to go inside the carburetor to determine the cause. Fooling with the external adjustments is not going to fix it.
