Posted by old on October 06, 2012 at 11:00:52 from (209.86.226.32):
In Reply to: carburetor trouble? posted by TTks54 on October 06, 2012 at 10:27:21:
First off when was the last time you serviced the air cleaner and made sure it was not full of water/dirt. Also look in it to make sure it is not full of dirt dubber nest etc. Next pull the rubber tube off the carb to air cleaner and make sure it is still good and not clogged up. Then try this. Pull the drain plug out of the bottom of the carb and let it flow a few minutes catch the gas to look for dirt/water etc. It maybe as simple as a little dirt not letting the float needle to seal so it flood easy or a clogged air cleaner
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
