Re: 3588 torque ?
Posted by Janicholson on October 06, 2012 at 14:55:58 from (96.24.99.126):
In Reply to: Re: 3588 torque ? posted by Greg Hammel on October 06, 2012 at 13:23:10:
The control pressure comes from the MCV pump and control is determined by valving. The pump pressure is multi-function and not limited to the TA clutch. Brakes, Steering, and Trans lube are dependent on that pressure. If the TA direct clutch is deteriorating it can contaminate many other components. Living with it is not good.
If the pressure from the TA control is also weak at the lockup clutch (rear clutch) the tractor can both toast that clutch, and runaway down hill. (with possibly less than 100% brakes. !!!!
I believe in TA equipped tractors. They are very much a factor making the tractors desirable, and work horses. My opinion is fix it. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
