A generator does not care which way it is grounded, neg or pos. Some voltage regulators do but most you buy now days work with either ground. Ordinarily a regulator is marked if it is polarity sensitive, on the under side or on mount somewhere saying which ground it is. At any rate, you need to polarize it to the ground system you are using. Momentarily , with everything hooked up but before you start engine, flash the generator terminal to the battery terminal. Just use any kind of a jumper wire to touch them terminals so you get a spark and that will turn those little electrons so their north and south poles are pointing in the right direction.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
