As noted and first of all, the genny can charge at either Pos or Neg Ground and of course, you need to Polarize the genny BEFORE start up. Some VR's are labeled as suitable for use at Pos or Neg ground, so you might wanna check that. If its a batery powered coil distributor ignition and you change battery polarity the coil leads need swapped also as well as the ammeter leads (if it has one) or it would read bass ackwards.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
