Posted by TheDurk on October 07, 2012 at 09:27:06 from (174.44.3.72):
In Reply to: Viscosity of Hy-Tran posted by Super-H-Mike on October 05, 2012 at 14:18:11:
I just thought I would post this from Wikipedia. It was news to me but just as Jim said:
[quote:c7fc50ac17]Single-grade
A single-grade engine oil, as defined by SAE J300, cannot use a polymeric Viscosity Index Improver (also referred to as Viscosity Modifier) additive. SAE J300 has established eleven viscosity grades, of which six are considered Winter-grades and given a W designation. The 11 viscosity grades are 0W, 5W, 10W, 15W, 20W, 25W, 20, 30, 40, 50, and 60. These numbers are often referred to as the "weight" of a motor oil, and single-grade motor oils are often called "straight-weight" oils.[/quote:c7fc50ac17]
Plus a little bit of motor oil trivia(same source):
[quote:c7fc50ac17]Also, if an oil does not contain any VIIs, and can pass as a multi-grade, that oil can be labelled with either of the two SAE viscosity grades. For example, a very simple multi-grade oil that can be easily made with modern base oils without any VII is a 20W-20. This oil can be labeled as 20W-20, 20W, or 20. Note, if any VIIs are used however, then that oil cannot be labeled as a single grade.[/quote:c7fc50ac17]
So there really is no such thing as an SAE 10. There is ONLY 10W.
This post was edited by TheDurk at 09:46:42 10/07/12 6 times.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
