Re: Super M PTO Engagement Lever
Posted by Janicholson on October 07, 2012 at 14:58:29 from (96.24.99.126):
In Reply to: Super M PTO Engagement Lever posted by dpoc on October 07, 2012 at 14:30:02:
It cannot "fall" off once installed. I would be sure to use a washer on the shaft that the actuator lever is attached to. just thick enough to keep the rivet from rubbing on the engagement collar groove.
Just clean up the tiny burrs and shim it out to not rub. Jim
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
