Re: Farmall M Hydraulic Pump out put shaft seal
Posted by truckerlary on October 07, 2012 at 18:46:17 from (12.19.152.194):
In Reply to: Re: Farmall M Hydraulic Pump out put shaft seal posted by David G on October 07, 2012 at 17:51:06:
You don't have to take the pump apart. Just stick a rod of somekind down the oil fill hole to keep the pump from turning while you remove the coupling.
