Re: M that fowls # 4 hole
Posted by robgIN on October 08, 2012 at 09:32:48 from (76.208.5.78):
In Reply to: M that fowls # 4 hole posted by mattwillson on October 07, 2012 at 17:47:56:
what does the plug look like, just black fuel fouled or is it oil fouled? Compression test first, then a cyl leakage test if you have access to tester. Need to find the root cause or will just be throwing parts at it. All the suggestions are valid, a little time diagnosing will save you time and money in the long run.
