Posted by Janicholson on October 08, 2012 at 10:01:00 from (199.17.6.20):
In Reply to: wireing problem posted by BigTone on October 08, 2012 at 09:37:07:
As old indicates there is only your preference. The generator needs to be polarized (as per John T instruction) to set it to generate with your choice of polarity. The amp gauge needs to be connected so it goes negative when the lights are turned on when the tractor is not running. If negative ground (like todays cars) the coil should have the negative terminal connected to the dist. if positive ground (as it came from the factory) the coil should be positive to the dist. The wiring is only different in those areas. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
