Re: 1st, 2nd and 3rd gears all the Same
Posted by Denny on October 17, 2000 at 15:08:54 from (12.4.181.2):
In Reply to: 1st, 2nd and 3rd gears all the Same posted by Paul on October 16, 2000 at 20:24:05:
I hate to disagree with all you guys, But Paul didn't say a thing about the tractor to make me think it's stuck in gear, That when ever he lets the clutch out it moves, and if it's stuck in gear, how does it move faster when he put's it in 4th? He has a loader on it, He has to use reverse. The tractor shouldn't move. It should be in 2 gears at that time which of course quickly destroys the transmission. 400's are easy to get stuck in gear if the TA is a little out of adj. There's nothing You guys have told him that will hurt anything, But I think we need some more information from Paul, I don't think we've solved the man's problem.
Post A Followup
: Re: Re: 1st, 2nd and 3rd gears all the Same
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
