Re: Timing light wont light
Posted by Jim Becker on October 08, 2012 at 12:18:35 from (173.74.120.222):
In Reply to: Timing light wont light posted by BigTone on October 08, 2012 at 11:02:32:
Given this and your other thread "wireing problem" where you say you didn't get a spark when you tried to polarize the generator, I'm going to say you don't have a connection way back where those circuits are common, somewhere between the battery and the voltage regulator. i.e. battery connections, ammeter connection etc. Take a 6-volt test light or a volt meter and start working backwards until you find voltage. Make sure the battery ground cable is well grounded, not just bolted down to some paint or some rust.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
