Re: Timing light wont light
Posted by BigTone on October 08, 2012 at 13:54:28 from (67.248.255.222):
In Reply to: Re: Timing light wont light posted by Janicholson on October 08, 2012 at 13:05:29:
I did everything you said and it didnt light at all. With the wire on the distributor the light did not light up, so i disconnected the wire from the distributor and the test light lit up, so I have power going in and coming out. you said the points might be grounded or not adjusted, how do i check to see if the wires are grounded or how do you adjust the points? also, how do you remove the black disk (dust cover maybe?) on the inside of the distributor so i can see the points/condensor?
thank you so much for the help Jim, i couldnt do this without you...~Anthony
