Re: Timing light wont light
Posted by kevinj54 on October 08, 2012 at 16:08:06 from (50.36.187.64):
In Reply to: Timing light wont light posted by CJ Johnson on October 08, 2012 at 11:02:32:
I read this to say that you have not been into the distributor yet. Is that true???
If so, pull it back off and check the weights, bearings, replace points, condenser, etc. set it up on the bench then reinstall.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
