Re: rear blade advice..
Posted by marvin on October 17, 2000 at 16:02:14 from (134.134.248.26):
In Reply to: rear blade advice.. posted by gn on October 17, 2000 at 06:52:47:
The throttle on your 140 is probably like the throttle on the super a that I have. On the lever arm that you move back and forth is a tang that sticks out to the right when viewed from the seat. The plate that it sits next to has a set of notches that the tang from the lever will sit in. Both the notches and the tang should have sharp edges on them to hold the throttle at a given setting. You can clean up the edges on the plate by using a triangle shaped file. Sharpen it like you would a saw blade. Make sure that the bolt holding the throttle lever is tight. If the tang is worn and rounded off then you will need to take it off and file a sharpe edge on it again or build up the area with weld and then sharpen it. One of the other suggestions to break up the ground first is a good idea. I have taken a plow to an area first and then started pushing and pulling the dirt or rocks. Anything that will break up the surface some will help. It does not have to be broken up too much, just enough to get the blade below the surface and start cutting. Good luck and post some pictures of your project. Love to see those old tractors at work.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
