Re: Changing rear tires on H
Posted by TomH on October 17, 2000 at 16:12:22 from (206.99.145.166):
In Reply to: Changing rear tires on H posted by PatB on October 17, 2000 at 15:44:59:
Just did this last week, so the memory is fresh. - Spray all the nuts with a good penetrating oil (like PB Blaster). Spray them again the next day. - Get wood blocks for cribbing and use a hydraulic jack so you can adjust the tractor up and down. - As Red said, get a long extension for a breaker bar (you'll probably destroy a ratchet, use a breaker bar). You risk breaking the socket or the bolt, but that's not a big deal. Be prepared to grind nuts off if they are rounded. - Best is to have another tractor with a front loader handy to lift the tire/rim; especially if there is fluid in it. Otherwaise have several pairs of arms to help. Don't work alone. - Rim should come right off the wheel. If it doesn't, hit the tire with a sledge hammer or gently pry it off with a pry bar. Once the clamps are off you can use the weight of the tractor and jack to break it loose but they usually don't put up much of a fight. - Be careful, a tire full of fluid could weigh over 600 pounds. And don't break the valve stems.
Home
| Forums
Today's Featured Article -
Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
Latest Ad:
1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
