Re: M Belly Pump
Posted by Janicholson on October 09, 2012 at 13:25:12 from (199.17.6.60):
In Reply to: M Belly Pump posted by Richard I. on October 09, 2012 at 13:12:35:
Removing and transporting the pump possibly got a piece of trash stuck in the pumps valving.
If the lever to stop stud distance on the tractors are different, the rod length could be allowing the hold position to actually be the lower position. Jim
