Re: F12 gaskits
Posted by Nebraska Kirk on October 09, 2012 at 17:47:05 from (207.91.4.159):
In Reply to: F12 gaskits posted by smiddleton on October 08, 2012 at 20:14:44:
You will save a lot of money by making your own gaskets out of sheet gasket material. If you get a head gasket kit, it includes the head, manifold, oil pan and valve cover gaskets, Victor part number is FS1396. All other gaskets can easily be cut out of gasket material. McMaster-Carr carries vegetable fiber gasket material in 1/16", 1/32" and 1/64" thicknesses, 3 feet wide and any length you want. All you will need is a pencil, heavy-duty scissors a small hammer and a cheap set of hole punches. Just lay the part on the gasket material, trace around it and cut out the gasket, use the hole punches for bolt holes. Works like a charm, I have made many gaskets this way.
