Re: fast hitch problem
Posted by IH fan on October 10, 2012 at 09:58:59 from (108.238.229.210):
In Reply to: fast hitch problem posted by Allan In NE on October 09, 2012 at 20:43:44:
That may be true, but without the flow check it will drop fast with a heavy load. Probably the heaviest thing we had on our SC Fast-Hitch was the 7' disk and I'm sure it would have dropped pretty fast without it. If all he's using on his 3 point is a back blade, he probably doesn't need it, but with a bush hog type mower or a disk, he'll think the bottom dropped out when it pitches him up on the steering wheel (well, maybe that's a slight exaggeration). I think he needs one, and the Parker valve is pressure regulated so it will flow approximately the same with or without a load.
