Posted by Janicholson on October 10, 2012 at 17:51:31 from (96.24.99.126):
In Reply to: Re: Where's My Dipstick posted by Dude with a 300 on October 10, 2012 at 17:17:31:
Answer; the side of the oil pan has two small projections on the side. These are petcocks (valves). if you open the top valve on level ground, the oil should drip from it if it is full. If the bottom petcock is opened and none comes out it is considered low. So keep the level between them. Filling till it comes out the top one when checking was SOP when running them hard. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
