Re: H magneto timing
Posted by pete 23 on October 10, 2012 at 18:00:41 from (74.32.238.2):
In Reply to: H magneto timing posted by BruceS. on October 10, 2012 at 16:34:18:
From factory, H came with two marks close together and one by itself. The two marks, first one to come around in normal direction of rotation is tdc and second is 5 degrees atdc. The lone mark is to grease pilot bearing in clutch. When fire crater pistons are installed the pulley is supposed to be marked 22 degrees before tdc which would be a little over an inch. I remember the M distance, it is 1 7/16 inch but don't remember the H for sure. Time mag to tdc if you like but I much prefer a few degrees after tdc to be safe. They have such a long impulse lag that it will still be more than enough advanced when running. I should add, that on magneto equipped engines IH also made a special impulse coupling available when using fire crater pistons.
