Posted by gene bender on October 11, 2012 at 02:29:06 from (67.55.227.68):
In Reply to: bolt clip posted by tuckaway on October 10, 2012 at 18:59:09:
They used that clip starting in 39 it was for installing the mag. Your dist has a base that you use for setting the timing on the dist that clip is not even needed for a dist as it will not move enough to time a dist. Its just the way they built them. Dont know it a mag was available for the 100 but mags were available for many yrs.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
