Posted by F BH44 on October 11, 2012 at 02:48:50 from (64.85.217.175):
In Reply to: Where's My Dipstick posted by Dude with a 300 on October 10, 2012 at 14:42:42:
I put a dipstick in my "H". There's a cast boss that sticks out on the side of the block, just ahead of the filter. Remove the oil pan, get the sharpest drills you have, and start drilling in the center of this boss, at the correct angle down, so you'll miss the crank. Drill a bit, then open that hole up with the next size drill, then go back and drill further with the first drill, the object being not to break off a bit. I had to drill thru 2 3/4" of cast iron. Tap the hole, get a piece of 3/8" tube, as i recall, re-thread it from NPT threads to fine threads, and installthat. I got a Ford dipstick, put it in, and make sure it misses the crank. (Mine misses the crank by 3/4".) Remove all the chips and filings. Works great, and truth be told, I check the oil much more often now. I used to check it once a year. Dipstick looks real cool too.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
