Maybe , but tomany times guys think that oh wait a min. this ring gear needs to be tightened up and they start messen with pinion depth and resetting back lash on and old gearset . And you end up with a noisy ring and pinion . always check the old back lash first and with heavy grease check where the pinion sets in the ring gear for a pattern when you start changing bearings and keep all th3e org. shims on the same side as they came from. Just because the book says .009 -.0012-14 is what it should be NEW this is not going to be the case with OLD on new bearings . so if it had .025 on back lash on the OLD and on the new it ends up at .018 leave the back lash alone .and check the pinion pattern with heavy grease if ya don't have a red or white lead . Don't ask how i how this.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
